i have a 91 rs with a megan racing 4-2-1 header on. that little bracket near the oil pan was nowhere close to fitting as some people have mentioned before. and it hangs way below the crossmember, causing my cat and everything else to hang low. does anyone know of a header with better clearance? pics? thanks a lot
greddy 4-2-1 It’s alittle pricy but well worth it. It evev fit when I did my b18c1 swap
thanks for the input, so this thing really has as good of ground clearance as stock?
yeah It even bolts up to the bracket that it’s suppose to.
thats awesome, too bad megan didnt get it right. i guess you get what you pay for
my megan bracket fit perfect/ and ground clearance was like stock
dunno
Neuspeed N2
soontobe2ndGEN is your teg 90-91 or 92-93. mine is 91, im thinking that might have something to do with it.
neuspeed header? dont see that around too often. ill look into that as well, it bolts up like it should and doesnt hang below crossmember?
