need help 1991 db1 wont start and i have checked everything dont know
When I go to start the car it won’t turn over and I checked all fuses and I just have no clue what it could be can any one help
check grounds… mainly the ground from the battery to the top of the transmission.
Also on your starter, there is a clip type plug make sure it is firmly seated. This littl plug will be right next to the screw down connection on the starter.
check the rest of your grounds as well. once you looked over all of that disconnect your negative cable for 30 sec, then reconnect and try to fire it up.
After you do this post back. If you are still having an issue you will need to start looking at the ignition system & also check for the 3 must haves… Fuel, Air, Spark.
have u tryed rolling n popping the clutch?
When you say, “it won’t turn over” do you mean starter motor is not working, or do you mean starter works, [engine turns over] but engine will not fire, [start/run]? 94
thanks everyone for the help it was a starter ground wire and a ground under the dash
