need help asap!!!!
putting in a b18c1 into 92 gsr need to know what mount to use on the driver side??? also the b17a harness is being used on the b18c1 but the b18c1 does not have an oil temp sensor on the back of the block like the b17a???
need help asap motor is going in tomorrow??? thanks guys
http://www.g2ic.com/forums/announcement.php?f=14&a=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
