need help asap
i had a tire go completly flat on me today while i was turning and i hit the curb and destroyed a rim, my problem is i also bent the hell out of my lower control arm and was wonder if i should replace the upper at the same tim or what??? also should i look at the stabilizer bar? is there anything else i should look at replacing or at least taking a look at? im not lowered or anything but it pulls very hard to the right but i think thats cause of the tire. its not even driveable but im hoping i just gotta replace the lca, but the tire was bent back pretty far, any ideas??? :think: :think: :think:
http://www.g2ic.com/forums/announcement.php?f=30&a=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
