need help asap
how do u install the rear side windows my window was smashed in and i needa repalce it
This is going to get closed for not having a proper title LOL…
Since its smashed out might as well clean scrap up all the left overs of glasses and most importantly the glue that kept the window together. Use a razor or something. Pretty much the clips i would say buy them new at dealer if they broke.
To install just buy new window and go to kragen or autozone and ask for window sealant etc.
Follow instruction and you will go far. Obviously you didn’t just like the title.
http://www.g2ic.com/forums/announcement.php?f=31&a=13
[SIZE=“6”]USE APPROPRIATE SUBJECTS[/SIZE]
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
