this might not be in the right section but i need a quick response.
i lost my keys and need to open my hood. no negative comments just tell me how to pop my hood.
THANKS.
THANKS.
:rules:
but there should be a black cable under your driver side fender, i guess all u do is pull it, should pop your hood open… nvr tryed b4 though…
http://www.g2ic.com/forums/announcement.php?f=31&a=13
[SIZE=“5”]USE APPROPRIATE SUBJECTS[/SIZE]
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
