I’m posting this in this section, because it seems like no one checks the other thread I posted in another section.
I need help quickly. My 91 Integra LS is not starting. Here’s what happen.
Decided I need some new spark plugs, so I bought NGK Iridiums.
Replaced old plugs with new ones.
Went to start the car, but it wouldn’t start.
Knew it was the starter, because it had a clicking/ticking sound.
Tested the starter at Autozone and found out the starter went out.
Got a working starter.
After I install the new starter, it cranked for four times, but it wouldn’t start.
After 4 times, it went silent.
I try to start the car, but nothing will happen.
The battery is good.
The distributor is new.
The plug wires are new.
I don’t know what’s wrong and need help asap, my DA is my DAily and it’s my only means of transportation. I’ve been getting rides to work from friends, but I need my DA. If anyone can help me, I would deffinitely appreciate the help. Thanks G2IC
POSTING IN THE CORRECT FORUMS
So you’ve run a search and didn’t find anything, so you need to post a new thread. G2IC forums contains A LOT of different boards. Each one has a description. If you need HELP with something, chances are you need to post in the ASSISTANCE section. ASKING IF A PARTICULAR PRODUCT IS GOOD SHOULD NOT BE POSTED IN ASSISTANCE, BUT RATHER IN THE PRODUCT REVIEWS FORUM. [SIZE=“3”]You may NOT post in the General Discussion forum (or any other wrong forum, depending on your subject) just because you think it will get more attention and you’ll get your answer sooner![/SIZE] Read each forum’s or category’s description to help you decide which forum you should post in. It’s a no brainer. If you post in the wrong forum, the thread WILL get (re)moved and you may lose track of it.
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
