Need help. B20b
I know this is not a stock motor. But still need help. Im doing the water pump and cnat get the water pump to come off. Even hit it with a inpack wrench.not a real big one mabye middle size.any idaes.
Try a rubber mallet on the water pump?
+Rubber mallet. Unless someone used JB weld on that thing (and all the bolts are removed), a couple of light whacks with the mallet should knock it loose.
Any luck?
