today, as i was driving in 5th gear, i was doing roughly about 65, when i decided to step on the gas pedal a little harder. just when i did that, the rpms went up a bit without the car actually changing speed and then the rpms went back down and accelerated like it normally would. any ideas? it does this in both 4th and 5th gear? any relations to clutch or something like that?
http://www.g2ic.com/forums/announcement.php?f=29&a=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
