need help car pulls to the right bad
OK so my car is pulling to the right really bad lately I’ve noticed that the passenger side tire is pushed back alittle could thus be the case
Alignment.
^ what MattyG2 said … and check to make sure nothing is bent or broken in the suspension.
Get an alignment and let us know how it feels after
Check your brake caliper, remove and grease your slide pins. Otherwise if you think there’s a problem with the wheel, jack the passenger side and try to shake the wheel to see if any suspension parts make it feel loose. It should be very tight.
