need help changing gearbox
hey guys my S1 gearbox was crunching gear pretty bad so i pulled it out and gota change over gearbox from the wreakers they gave me a good ys1 gearbox now i noticed the brand new clutch kit i bought the input shaft spline is too small on the clutch and is to suit the s1 transmission now can i still use the YS1 gearbox on my car if swap the clutch kit for a 93 teg or will that not bolt up to my flywheel and are there any other things i will need to change cause if its too much of a drama i can take it bak to the wreakers and swap it for the right gear box also witch is the better gearbox of the two the S1 or the YS1
i worked out i can swap my 90 clutch disc for a 93 disc that will work but i bought i clutch kit with the pressure plate aswell will a 93 pressure plate bolt up to a 1990 flywheel and are there any other diffrences apart from clutchs
The clutch disk is the only part that is year specific. All b series pressure plates and flywheels are interchangeable.
The only other difference is that cable and hydraulic transmissions use a different release bearing. But that doesn’t effect you since both of your transmissions are cable.
