i have a 90 teg,ls/vtec…running a pwo ecu…i am have a problem…i have code 23…knock! but it is throwing a code 2,if iam reading it right,but never hared of code 2…if iam reading this worng…tell me…it well falsh two long ones…and 3 fast…23…and 2 fast ones…2… help me …:shrug:
maybe the 2 flashes means #20…ELD…electric load detector…but should be 2 long flashes
not an ECU guru…which is a PWO?..OBD0?..you need to disable both knock and ELD from the ECU
are cars dont have ELD. so no need for it
how do u disable it…with have the check engine light come on?
i use Crome to disable mine
thanks…but have the $ for that
