Need help differing transmission mounts from motor mounts
Hey so I have a 91 integra ls automatic and 1 or 2 of my mounts is not working properly… It also started with that clunk noise. After checking some of the mounts out i noticed one of them had the rubber sticking out so i figured it must be the one or one of the ones that are broken. When going to a local auto parts store its hard for them and me to identify which is a transmission mount and which is a motor mount. Here’s a picture with numbers where the 4 mounts are located… number 2 is behind the intake manifold…
Please help me identify which is which, please and thank you!
1: Transmission Mount (mounts to transmission via brackets, then to chassis)
2: Rear Mount (bolts to subframe then to a T-bracket that connects to the motor and transmission)
3: Driver-side Motor Mount (from engine to chassis)
4: Front-Transmission Mount (front sub-frame to transmission)
[QUOTE=unified112;2293420]1: Transmission Mount (mounts to transmission via brackets, then to chassis)
4: Front-Transmission Mount (front sub-frame to transmission)[/QUOTE]
Thank you very much! Needed this info
91 automatic engine/transmission mounts…
http://www.acuraoemparts.com/delray/jsp/prddisplay.jsp?inputstate=5&catcgry1=INTEGRA&catcgry2=1991&catcgry3=3DR+LS&catcgry4=KA4AT&catcgry5=ENGINE%2BMOUNT&ListAll=All&vinsrch=no 94
hate to bring this back from months, but im new to tegs coming from bimmer land. right now Im trying to remove the front transmission mount and replace it from the top but its giving me a real hard time… car is an automatic 91 LS
whats the best way to remove it and replace?
