need help finding these clips that hold the engine harness in the bay
hey guys, i need some help finding these clips. im in the progress of re-doing my engine harnness and i need new clips to hold it in place.
here what they look like. These clips hold the engine harness in the bay.
they look like a zip tie combined with a clip… i try searching in ebay to see if i find them but i had no luck… any info… part number… or similiar product that can work would great!
Finding those are an absolute nightmare and most of the ones unique to our chassis were discontinued long ago. I have some info in this photo album: https://www.flickr.com/photos/clen/albums/72157626161113711 (at one point I had my friend that works at a dealer send me a bunch of different ones since they’re really really hard to pick out in the online parts diagrams).
If you can’t find new ones you can try to reuse old ones, even hit up junk yards to get more. If you remove them carefully they can be reused.
[QUOTE=Colin;2334489]Finding those are an absolute nightmare and most of the ones unique to our chassis were discontinued long ago. I have some info in this photo album: https://www.flickr.com/photos/clen/albums/72157626161113711 (at one point I had my friend that works at a dealer send me a bunch of different ones since they’re really really hard to pick out in the online parts diagrams).
If you can’t find new ones you can try to reuse old ones, even hit up junk yards to get more. If you remove them carefully they can be reused.[/QUOTE]
Thanks for the reply! i will deff look into the link and see if it helps!
Yes i know i spend some time looking around and ended up with nothing lol. i guess worst come to worst ill re use old ones.
this is a close as i found… not sure if the clips will fit tho…???
http://www.clipsandfasteners.com/searchresults.asp?searching=Y&sort=7&search=harness+clips&show=45&page=1&cat=180
http://www.ebay.com/itm/5-Clip-mount-releasable-wire-cable-harness-tie-straps-black-plastic-/221812832637?hash=item33a513397d:g:C3cAAOSwxYxUtJeY&item=221812832637&vxp=mtr
http://www.ebay.com/itm/100-Releasable-Cable-Strap-Clip-Push-Mount-Wire-Tie-142mm-For-Honda-For-Mazda-/161913584938?hash=item25b2cd3d2a:g:ELIAAOSwnH1WaQMo&vxp=mtr
I bought these at Canadian Tire in Canada. I figure something like Napa in the US would have this. I’ve only used two so far but they worked in the place I put them. One was for the wire harness on the driver’s side near the master cylynder. The other I used it to hold the O2 sensor on the exhaust because I removed the intake manifold support on the back of the engine. There’s a screw hole on the front of the oil breather box that was for this bracket. I put one of these in this screw hole to hold the O2 sensor connector. It pushed in perfectly, and actually can screw in. I think it is a 12mm screw hole.
http://www.canadiantire.ca/en/pdp/8-in-push-mount-50-lb-cable-tie-0207578p.0207578.html
[QUOTE=93IntegraGS;2334506]I bought these at Canadian Tire in Canada. I figure something like Napa in the US would have something like this. I’ve only used two so far but they worked in the place I put them. One was for the wire harness on the driver’s side near the master cylynder. The other I used it to hold the O2 sensor on the exhaust because I removed the intake manifold support on the back of the engine. There’s a screw hole on the front of the oil breather box that was for this bracket. I put one of these in this screw hole to hold the O2 sensor connector. It pushed in perfectly, and actually can screw in. I think it is a 12mm screw hole.
awesome ill check napa and the local auto parts to see if they carry that ! that seem like it might work perfect
You can actually still get some of these part numbers.
91554-SH3-003 BAND, WIRE HARNESS (100.5MM) (NATURAL) MSRP $2.63
91570-SH3-003 BAND, WIRE HARNESS (NATURAL) MSRP $1.73
91547-SH3-003 CLIP, BAND (160MM) (NATURAL) MSRP $1.73
I just checked the availability (I work at a dealer) and they are all still available.
[QUOTE=Jschleng81;2334508]You can actually still get some of these part numbers.
I just checked the availability (I work at a dealer) and they are all still available.[/QUOTE]
Ones like those which are more common to multiple chassis’ are still available, but anything that is specific to our chassis is likely gone. It’s really disappointing :frowning: . Recently I checked literally the entire oem catalog and there were only a small handful of SK7 part numbers still available (of course there are other parts specific to our chassis which are not coded as SK7).
The first and last on your list are pictured in the link I posted earlier - unfortunately they are not the ones he’s looking for :frowning: . The first is a very specific application used to hold a wire loom and two additional cables (e.g. trunk latch cable & maybe the antenna cable). These are used inside the cabin of the car. The last one is another specific application used to hold a wire loom but attaches to a post instead of popping into a hole. These are used on our firewall (both sides). All of this is documented in the link I provided. I can’t find a good pic of the middle one (91570-SH3-003). If you happen to have one at your dealership is there any chance you could snap a pic for us? If it happens to be the one he’s looking for then I’m ordering some ASAP. It’s been a couple years since I was hunting for these but I’m pretty sure that is one of the ones I couldn’t track down and/or was discontinued. I had my friend at a dealership sending me random wire ties he found because trying to determine what’s what in the oem catalog is pretty tough and often you just need to order the part and get it in your hands to see if it’s what you need.
Ok fellas, these came in this morning. One of them seems to be similar to what you may need. If anyone needs closer pics or angles let me know.
[QUOTE=Jschleng81;2334559]Ok fellas, these came in this morning. One of them seems to be similar to what you may need. If anyone needs closer pics or angles let me know.
the first and last looks like it may work. The one in the middle is for the inside harness connects to the firewall bolts that stick out. the skinny ones. The last one seems to be the closest. it might actually be the right one.
I just re used my clips. they worked great… and saved money.
That third one looks like it could work but it’s definitely not the same as the ones you pictured. It doesn’t look familiar to me, I can’t picture where it might be used on our chassis.
