i bought a 90 coupe today. and noticed the passenger side front and rear tires have a crap ton of positive camber to them. not negative camber like how everybody is going for that “stance” look but my wheels are cambered out the other way!! and its scary as hell lol. and also my car has alot of over steering. for example i would turn a corner and when i straighten out… i feel alot of weight shift and feel like im going to lose control.
i put the car on a lift and havent noticed any bent or damage suspension components so i want to ask you guys for any tip or if anybody knows why my car is like this. the only thing i found wrong with my car is that the trailing arm bushings are bad and i need a new rack and pinion because the boots are ripped. any input will help alot!! thanks g2!
no sorry. im cruising g2 on my iphone and it wont let me upload pics for some reason. but the wheels are so tilted that it seriously llooks like its going to fall off. i had one of the techs look at it but even they say that they dont see anything bent or damaged.
I know if you replace the knuckle from a g3 in a g2 it will give you horrible positive camber. As for the rear, do u have adjustable toe? thats the only thing i can think of the top of my head.
Ya I just barely got done with an alignment and is all jacked up! Lol I adjusted my front and rear toe to its best and its still looking all weird
Yeah man try buying different knuckles. You really cannot tell if you have dc knuckles without comparing it side by side with the da. Without pics we can only assume. Sorry i couldnt help much.
It’s all good. Thanks! Ill let I guys know when I come up with a solution lol
