Just picked up a oem hatch visor all mounting gear and instructions are somewhat hard to figure out. Anyways I cant figure how to put it on. I cant figure out how to put on the upper brackets on the hatch. Anybody have any advice?
Also where can I buy double side sticky tape because the one on the brackets is pretty much worn out?
Mark the holes from the visor on the hatch. Then tilt the bracket towards the roof and then pull it onto the rear hatch. Make sure to get some good double sided tape. You can get it at a paint store. Also make sure to clean the window with rubbing alcohol before you put it on.
Heat up the tape with a hair dyer until the plastic ( on the tape the part you peel off ) rises alittle . Its a truck i learned a while ago . If you do that it will hold onto anything .
