need help on code #9 it the No.1 cylinder position sensor
I rest my ECU and the back up fuse and it did kill the check engine light but when I start up the car again and let it idle and a few second the check engine light is back on again and it still the code #9 need help on this problem.
http://forums.g2ic.com/showthread.php?164955-CEL-Code-9-D.I.Y.-fix
http://forums.g2ic.com/showthread.php?207548-CEL-code-9-CYP-sensor&highlight=crankshaft+position+sensor
that and many other threads. Take some time to search. It’s been discussed many times before.
thank again spikeymike I read and follow step by step to fix code #9
