Need Help...QUICK
Im changing my suspesion, i cant seem to get the rear back in, the shock/spring assembly seems too long, but i know it will fit in there, is there some trick to it or anything?
put the bottom of it on the ground and push the shock down as hard as you can…then put it back in
top first then push it up from the bottom to get the bottom bolt holes lined up
that would be too easy. haha… the spring just presses it back up, they are sportline springs, so i know they will fit in
where in the bay area are you located?
I just did a car with h&r sports (pretty much same height as the sportlines) and a car with coilovers this month. Thats how I got them in.
I had to undo the sway bar and use a jack to bring the lower control arm back into place. The rears took me wayyyyy longer than the fronts. :tsk:
