need help re-aligning my doors
hi i have a 90 4dr and my doors are not strait with the body. I need some help or more like some instructions on how to make my doors sit flush with the rest of the body.
not sure if this is going to help but its worth a shot-
my grandpa has a 1991 ford ranger & we recently took the door off & tried to put it back on. upon reattaching it we could not for the life of us get it to align back up to the chassis. the next day he took it to the dealer & they used some “special tool” my gpa called it to get the door to sit in its proper position.
so possibly an acura dealership can help u out
good luck
ya im sure they will be able to fix it and then charge me up the ass. hahhaha. I think i might just do that thought and pay the bitches and save my self the headake for another day.
try and just crack the door open and put it on a jack stand line it up as strait as you can with the lower door frame.
tighten it up, and check it, if it still hangs, mark the top hinge with a sharpe or somthing and move the hinge forward to cover the mark.
Check and repeat as necessary:up:
:werd: That’s what I did.
[QUOTE=BLKACK1;1722610]try and just crack the door open and put it on a jack stand line it up as strait as you can with the lower door frame.
Check and repeat as necessary:up:[/QUOTE]
x3
if the top hinge is all the way in, it looks like its time to pull the bottom hinge out:shrug:
