need help replacing radiator
from what I see… 2 bolts on top, upper radiator hose, and the fan…
anyone have instructions on removing the radiator?
You got it.
Sort of like painting - most of the work
is preparation or in this case getting to the radiator ie. removing hoses, fan shroud ect.
If you have an auto tranny, you need to disconnect
those hoses from heat exchanger.
pretty easy imo. hardest part i think is just nudging the fans out. you should probably get a haynes or something. i think its easier if you do it in a certain order i forget. good 12$ investment anyways
