need help rewiring fan....
ok so i am threw with running my slim fan to the distributor because it cut the wire off and need some help on another way of rewiring it. so please help me out…
What do you mean by connecting your slim fan to your distributor? Why not just use a switch to turn on your slim fan?
Why not just wire it up to the stock relay and switch?
well i wanted to have the fan running direct. and i dont think the plug on the stock harness isnt there no more to plug onto the one for the fan. when i got the car the fan was running to the distributor…so i want to find another way to run the fan direct…
set up a relay circuit with a switch in the cabin…
if you don’t have the stock connectors, buy a flex-a-lite adj. temp sensor
http://www.flex-a-lite.com/auto/html/electric-fan-accessories.html
