need help: usdm 2000 ITR cams vs. jdm 98 itr cams
hey fellas i found a good deal on both of these cams and want to know which one is better?
i know the lift duration is higher than my stock b16 cams but which one of these 2 sets are better??
lmk asap thnx much!
I believe the 2000 ITR cams are the better grind and closer to the CTR grind. But the CTR/PCT cams have 3* more duration the the ITR. Most say it’s not worth the 3*.
oh ok, i was asking because i found both these cams for a good price and was wondering which one is better.
im running my stock b16a cams and wanted to upgrade to some itr/ctr cams. since theyre not as aggressive as stage 2’s
so even tho the 2000 itr cams are usdm theyre the closest to the ctr cams?
[QUOTE=Da_lover;2262665]oh ok, i was asking because i found both these cams for a good price and was wondering which one is better.
so even tho the 2000 itr cams are usdm theyre the closest to the ctr cams?[/QUOTE]
I’m pretty sure that is correct. I will ask my brother b/c he just bought 00/01 USDM ITR cams for his B16/GSR block/PR3 pistons. IT might be b/c the USDM ITR had lower compression than the JDM ITR. Maybe they gave it a more aggressive cam to make up for it?? OR, maybe the compensation is in the tune. IDK I will talk to him tonight b/c I’m about to be in the market for some ITR cams for my LSvtec with B16 head. Someone might be able to answer prior to that though.
sweet thnx for the information, greatly appreciate it! :salute:
Here, let me Google that for you.
you got schooled :read:
98-00 are all the same 98 spec cam, trust me when I say the 01 itr or ctr cam with 243 in duration over the itr 240 does make power.
I had a 01 jdm itr swap and I was taking out 98 spec itr.
money wise its up to you.
[QUOTE=da6xsi06;2262694]you got schooled :read:
money wise its up to you.[/QUOTE]
oh ok so theres no difference between the 98 spec and 00 spec then? i thought the 00 spec had longer duration than the 98 spec? i know the ctr cams are the most aggressive out of all of them.
00-01 itr cams=CTR cams>94-99 ITR.
The duration on the intake cam of the 00+ ITR and CTR cams is a few degree’s more than the older ITR cams.
http://www.b20vtec.com/forums/b-series-tech/724251-ctr-00-01-itr-cams-identical.html
