need help, water leak!
Hey all, not sure if any of u have this problem but Under neath my dash where the passenger side is as well as driverside, when ever i make hard turns, it leaks water. Only happens when I have my ac on. I checked at the drain tube from the blower housing and its connected. Anyone know how to fix it?
go to Teg Tips and look under interior “fixing wet passenger floor”
hope that helps =)
hmm dont know how to explain it but its the a/c cold air hot air thing right? thats where the water is comming from right? maybe that hose on the passenger side is cloged. just use a air compressor and blow it out. mine was cloged before too.
ok found the problem, the ac vent tube was clogged. When I cleared it, tons of water came out of it. Thanks for the help guys.
where is this ac vent tube ? how did u clean it ? Thanks
It is a tube under the car on the passangers side near the steering rack. The tube comes out behind the steering rack support .Use a wire hanger in the tube from under the car or unhook the tube from the air box inside the car and use compressed air (Be careful not to make a mess inside the car)
I had a problem like this on my Jeep Wrangler everytime after it rained I would make a turn and water would splash on my pants and shoes. There was leafs and dirt / slime inside that blocked the drain tube.
