Need Help What Engine To Swap
I have a 90 teg but I don’t know that engine to swap I’m not sure to get a b16a or a b18c1 can you give me the some good advice cause I only want the car to be relaible and the car be faster than what is now And what are the difference between the two.
Re: Need Help What Engine To Swap
b20 with high compression aftermarket pistons. Easy and you will be happy. Most people arent all that happy switching from a b18 to a stock b16 because of the loss of torque. However lots of people do it. If your deciding between a b16 and a b18c, do the ‘c’ definately.
this is kind of a stupid question. you’re comparing two completely different engines:
b16a ~$1200, 160hp
b18c ~$2400, 180hp
one is cheap and has a little less power. one is expensive and has more power. If you have enough to get the b18c then get it! if you can’t scrape up that much $$ then get the b16a. But the b18c is definitely a better engine (because it has more power), but you’re gonna pay a good deal more too.
the b16a swap isn’t gonna make your car much faster (if any faster) than the stock motor. You may also want to consider a b20 swap.
