removed calipers to paint…after install and bleeding my pedal was sinking to the floor…i thought that maybe after bleeding and putting in new brake fluid that maybe my dot 3 cleaned out all the gunk in the master cylinder and the seals were not holding no more, so i changed the m/c…problem is still their any suggestions?!? maybe brake booster?!? i doubt its because their is air in the lines…cause i bled the ish outta it…or are the abs models harder to bleed?!?
thanx for any help
