Well I just installed my new headlights, and I really like the look of them. Now for the people that are familiar with these headlights, how did you connect the 2 wires that control the foglights? Its just 2 wires with no connectors at the end. And is the foglight bulb an h3 bulb? Also, for the corner lights I noticed the stock has 2 bulbs but these headlights only accommodate 1. All I did was just take out the bulb on the parking light, will that be alright? Thanks in advance for any help.
well the jdm one piece are the same there is only one bulb in the corner light. ok well since you have a extra conection to your corner light hook that up to the wires for the fog lights so when you turn on your parking lights your fog light will come on your basiclly substituting the fogs for your corner light
and soorry but i have no intel if those are h3 bulbs
Yes they are H3! With regards to the extra corner bulbs, previous poster is right, it’s totally fine. I would connect the turn signal one though… And yes, the two wires coming out of the headlight are the fog lights, just cut off the connector from your 3 pieces and solder them on. Good to go, really very easy
Side note: Get an OEM front lip:werd:
Thanks for the advice guys, greatly appreciated.
Anyone know how to remedy the problem of the high beam indicator light being on even though the high beams are off?
U either wired up the lights wrong, light switch is going bad (this would be my guess), or u used leds and it is affecting the other lights (which i doubt but possible). Hope that helps.
the light stays on because its a different buld than the stock. i know the plug fits the buld but its 9007 vs. a 9004 i had the same problem because the three prongs on the bulb will not line up
[QUOTE=Vince92gs;2155247]You need to swap 2 wires
Take a look at this thread[/QUOTE]
Yup, that’s what you gotta do
Thank you for the help folks.
Hey bro, how did you install those? I’m having some serious fitment issues with mine. can you post up an under the hood, top-down pic of the lights? i really appreciate it.
Personally, I don’t like those ebay harnesses, so I took them off the headlight and I use my stock harness/9004 bulb.
^and I don’t know how you could possibly have fitment issues, unless your car was in a serious wreck and nothing lines up straight in the front
The only fitment issues I have is for some reason I have a gap inbetween the bottom of the headlights and the bumper. Ill try to get you those pics soon
see thats the thing… i bought it in 2000 and it LOOKED like it had never been in a wreck, now im starting to doubt it, although its not on record and the vin report says its a clean car.
