Need help with JDM B16A
The part you posted, PN: 90012-PM7-000, bolts to the cam-cap itself.
PN:90014-PR3-000 actually goes THROUGH the cam-rail, through the cam-cap, and into the cylinder head. Trust me, they’re different.
The inner studs are different than the outer studs, even on the non-vtec head, as you pointed out with Part #s 18 and 19.
so wat do u mean? wat part do i need to get then?
Read my last post… I list the PartNumbers and quantity needed.
[QUOTE=unified112;2203289]Not to be a dick… but there is a reason that when you look up PartNumber 90012-PM7-000, the Quantity Needed is 4, and that reason is because you are incorrect… There are 8 total fasteners for the valve cover.
I’ll say it again… the Plug/Wire Cover studs ARE NOT THE SAME as the outer Valve Cover studs.
The part needed would be #20 (x2) (PN: 90014-PR3-000 $5.75ea), from this picture:
And coincidentally, part #20 (x2) (PN: 90212-PR3-000 $2.80ea) from this picture, if you need new fasteners:
You would also need part #21 (x4) (PN: 90213-PH3-000 $3.08), if you installed a Wire Cover.[/QUOTE]
