need help with lights dimming
i pulled the motor out to replace the clutch… and now its been nothing but problems all grounds are good alternator is working charging the battery at 14.4 volts but if i step on the brakes all the lights and dash dim and a little smoke stated coming out of the cluster area i turned it off
and at idle if you have the heater on all the way it don’t do anything tell u rev it up same with the lights
