need help with my DA
k here is my sad story im converting my 90 ls from obd0 to obd1 i went to the junkyard found a gsr took out the entire wire harness from the engine bay plus the engine harness im running a b18a1 motor which is all is plug and play motor turns on everything works now my problem is i cant seem to figure out why every time i turn on my lights the turning signal lights on the cluster turn on and they start to flash slow and the lil box that makes the noise when the lights are on bearly sounds not only that my tep gauge goes from cold to hot and when i turn it off it goes back to normal i need some help asap need to have the car ready for my new job any help will be appreciated thanks in advance
Wrong forum.
But lets get this right,you pulled a GSR B18C1 motor and swapped it in you car,then used the GSR harness?? Why not use the LS harness and just run the Vtec wire to the ECU? You got a OBD0 to OBD1 ECU jumper right??
took out all the harness out so no obd0 all obd1 harness everything is obd1 from a gsr car i found at the junk yard so now its and 90 ls obd1
Start looking through the wires,you have something crossed or something.
Post in the correct forum. Use a more detailed thread title per forum rules.
