need help?
i am running into problems will b16 connecting rods and a b18 crank fit in a b17 block
http://www.g2ic.com/forums/announcement.php?f=14&announcementid=13
read that link it is the forum rules and how to post
this thread will be closed due to improper title,
“USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.”
