i just put some coils on my car but its to toooo Bouncy what can i do to get a smother ride in the front
you have to either raise the car up more… or buy better struts to handle a low drop. OEM struts can’t handle aggressive aftermarket coilover sleeves, especially if the car is dropped that low.
closed. vague thread title.
http://www.g2ic.com/forums/announcement.php?f=33&a=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
