Need help
This morning started up the car on my way to work and noticed that my clock was not working, dome light out, door open light stays on as well as the rear trunk light on the dash. Has this happened to anyone, if so can you help?
Thanks
http://www.g2ic.com/forums/announcement.php?f=32&a=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
