Hey I just bought a completly stock clean as fuck 1990 integra Ls, one thing i need a new motor the one in it is seized up and im just gonna use it as parts.
But my consern is what is the best motor to put in this car, i havent ever really messed around with these cars much but i have always wanted to but dont really have any knowledge about them, so let me know what the best thing to do to this car would be on a slightly limited/unlimited budget.
Thanks.
- Search
- Post in the correct forum.
- Use a proper thread title.
http://forums.g2ic.com/announcement.php?f=29
BEFORE STARTING A NEW THREAD…
Please run a SEARCH before you start a new thread. The search feature allows you to find answers to your question / comment immediately, since it is VERY LIKELY that your question was asked before. Searching also reduces the site’s bandwidth requirements.
Should you still have questions, it is better to reply to an OLD THREAD than to create a new one.
If you need to create a new thread (such as the case with an archived thread), include a link to the thread where you got your information from and would like to continue the discussion.
DON’T BE LAZY, SEARCH FIRST!
POSTING IN THE CORRECT FORUMS
So you’ve run a search and didn’t find anything, so you need to post a new thread. G2IC forums contains A LOT of different boards. Each one has a description. If you need HELP with something, chances are you need to post in the ASSISTANCE section. ASKING IF A PARTICULAR PRODUCT IS GOOD SHOULD NOT BE POSTED IN ASSISTANCE, BUT RATHER IN THE PRODUCT REVIEWS FORUM. You may NOT post in the General Discussion forum (or any other wrong forum, depending on your subject) just because you think it will get more attention and you’ll get your answer sooner! Read each forum’s or category’s description to help you decide which forum you should post in. It’s a no brainer. If you post in the wrong forum, the thread WILL get (re)moved and you may lose track of it.
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
