So I got my obd0 to obd1 jumper and I need to figure out how to run my check engine light wires, maybe a simple question, but I’m new to the whole Honda game and this is my first swap, thanks
What do the instructions say that came w/ your harness? On mine I didn’t have to do any extra wiring. On mine there was just a single wire that had to be jumped and it just negated the OEM CEL plug you normally jump.
on my instructions it only told me what each wire was, nothing detailed about how to put anything to what, but everything else was basic besides the check engine light, i dont know if i have to run the wires to the cluster itself and run it to the bulb or something or just splice the wires into my actual harness that the check engine light wires come from
Why don’t you try the help forums?
The CEL wire on the harness is a replacement for the stock CEL jumper, not something that needs to be wired to the cluster. IIRC you can leave that wire alone and when you need to check codes you just ground the wire. You can wire it up to the stock CEL jumper plug if you’d like or run it to a switch so that all you need to do is flip the switch to check codes.
