I just wanted to see how u guys setup your 1 pieces
Is this what you meant?
Use 1 inch crimps that connect stock wires to jdm wires. If that’s what you’re wondering.
hey ive, there are 2 fog lamps for each lense? can yyou not put in a bulb in the housing btwn the corner and the h4h?
No, there is only one fog light, one H4H bulb and one corner light per side. Access to the fog bulb is on the end of the lens behind where the bulb sits even though the 2-prong power input plug for the fog light is in between the H4H and corner bulb.
Good diagram Ive. That type of thing should be in the teg tips section about the 1-pieces. Awesome job once again!
jordan
Hey solid…if u get fed up with the one pieces let me know and i will buy them from u …=)
