Need some advice.
Recently, whenever its cold outside I go to start my car, and when I turn the key nothing happens. I have changed the battery already because I needed a new one anyways. but does replacing the starter seem like the next way to go? What is happening, is that I turn the key, and the car will just click. Eventually if I try to turn the car on over and over again, it will crank. Any help would be greatly appreciated.
http://www.g2ic.com/forums/announcement.php?f=29&a=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
