Okay so the really bad cold has hit where I live lol and I’m in the process of installing remote start on my car. 92 GS. The alarm is a Radiostar Generation LCD 2 way remote start with alarm and everything. I’ve already had the alarm portion installed for awhile now, just installing the remote start now. I have a picture of the wiring diagram from the alarm manual.
I have the purple, pink, orange, and red hooked up to their proper wires at the ignition switch. Right now I have the 2nd pink ignition wire hooked onto the first one before its hooked onto the car’s ignition wire, not sure if thats proper or not or if its needed to be like that…
I have the neutral safety switch hooked up to a constant ground for now just for testing purposes… I should put it on the e-brake wire later right (so it won’t start unless the e-brake is pulled right?).
I’ve got the brown wire from the 8pin hooked up to the brake switch properly. (I know this because I can remotely turn on the heater and stuff and then hit the brake pedal without disarming and inserting the key and it turns everything off)
I’ve got the Purple/White wire from the 7pin connector hooked up to the tach wire at the distributor.
I currently do not have the starter killer relay which is on the bottom right area of the picture hooked up. My understanding is that is only for protection if someone tries to steal the car? If it is then I don’t care about it…
I currently do not have the Blue/White (-)200mA Bypass Output When Remote Start wire from the 7pin connector hooked up anywhere.
NOW what I can do right now is I can attempt to remote start it and it turns on the fuel pump and the heater but doesn’t even make one attempt at cranking it. And I can also remotely turn everything back off with success.
I don’t understand why it is not attempting to crank the engine right now with the way I have stuff hooked up, but also this is my first attempt at installing remote start.
The diagram shows the automatic gear diagram but my car is stick shift. But I’ve got the neutral safety switch hooked up to the emergency brake so my understanding is it should work… I am the only one that drives my car and I NEVER LEAVE IT IN GEAR. Its parked on level ground every time its parked at I only pull up the emergency brake I don’t leave it in gear. So whatever I’ve got to do to make this remote start work on my car I will do, even if I’ve got to jerry rig something to make it work on stick shift.
I know its probably something brutally obvious which is causing it not to work but this is my first time doing this so please be nice lol.
BTW I would like to avoid buying any extra parts as much as possible because the car is currently immobile in my garage so I just need to get this done I don’t have time to be messing around with buying extra relays and shit if I don’t absolutely have to.
If any other pictures/info are needed to figure this out just let me know and i will get them.
Thanks in advance.
