need some help with my headlights
okay so i just installed my jdm one piece’s and i bought the harness from password jdm but when i put in my corners and turn on my blinkers they both flash at the same time…any help would be appreciated thanks
The front side markers, [corners] are controlled by the ICU, if both flash when using your signal lights then it is most likely a problem with the ICU. 94
even if they all my lights were working before i put them in?..cause before i put my one piece’s in the blinker would work to its respective side but now they both blink lol
Do the rest of the signal lights work properly, [rear signals and front bumper signals and signal indicators in cluster]?
Do the intermittent wipers work?
Does rear window defog work?
Do the warning chimes work, [seat belt, key still in ign. and lights still on]?
All the above are also controlled by the ICU, and a defective ICU is a very common problem on G2s. 94
yea everything works so i guess it’s not that i plugged in my blinkers into the corner light…then i plugged the fogs into the 2nd corner plug. used the conversion harness for the main light and i left that small little plug just dangling. I’m thinking it has to do with that plug that i left dangling
Not trying to thread jack but i also need some help. I used the passwordjdm headlight harness also and now my low beams are my high beams, and my high beams are my low beams. Could they have wired the low beam and high beam wrong on the harness? What could i do to fix this?
