New Clutch and Flywheel = Fluctuating Idle ? WTF HELP !
New Clutch and Flywheel, Fluctuating Idle? WTF HELP !
Just got my brand new clutch and lightened flywheel installed yesterday. Immediately after I left my mechanics house I noticed some things gone wrong.
  1. When I start up the car it immediately roars then drops down to a low rpm, instead of a gradual drop as usual…
  2. Idle fluctuates between about 500-1200 in a steady repetitive pattern
  3. Sometimes it will randomly find itself and stay around 500 (which is low) but not for long before it starts searching again…
  4. Check engine light came on after about 15 mins but hasnt come in since it turned off the at last.
So I check for codes, showed a code 43… O2 sensor was recently changed I also recently cleaned the Throttle body, Ftv and iacv…
First thing I did was bleed the cooling system. No change. Reset the Ecu and still no change however now I don’t see a code blinking…
I would like to add that the car had been sitting for about a month. But I started it about 2-3 times in that month with no idle problems.
Also th mechanic adjusted the clutch cable to initiate the clutch at higher point instead of having the clutch pressed all the way down…
Any ideas ???!
you get a lightweight flywheel as well?
i’m actually kind of having one of the same issues…
Yeah man lightweight flywheel
i wonder if it’s legit related or not…i never had bouncing idle issues until after my install
