new here/ DB1 build thread
UPDATES 4/20/12
well decided to start taking out the LS since had nothing to do and since im getting the b20 delivered on monday i said why not start early.
will post more tomorrow. lost daylight.
werd yout got to drop it more than 1.5
yeah but all depends first pics in this thread were fully slammed with my exhaust scraping on thr ground… but yeah all depends on how low i want it.
took out cruise control and also doing a small wire tuck. motor is going to look nice and is going to be healthy when in my car :slight_smile:
Great build man, Cant beat 1 pieces for $40 :up: have fun with that b20. Im sure youll really enjoy it :rockon:
b20 time!
new parts all going on the b20 this includes:
pcv valve,
oil,
radiator fluid
honda MTF
all new radiator hoses
clamps
radiator
intake manifold gasket
exhaust manifold gasket
NGK V-Powers
new spark plug wires
valve cover gasket
pwjdm cam seal
timing belt
water pump
timing tensioner and spring
new throttle body
blox tps sensor
today is the install!
Good luck with everything joe.
hows she running joe?
Can’t wait to see how this pulls in a DA!
look what i did today :slight_smile:
well the valve cover is in bad shape so i decided to polish it
INSTALLED! But will be running/driving tomorrow decided to use the b20 crank pulley and need a b20 alternator belt.
well not running until tomorrow :frowning: i need a b20 alternator belt and i also have to get or take off power steering since my B18 one wont work with it.
i also lucked out and it has a brand new timing belt, water pump, timing tentioner and spring. glad i dont have to replace them since there brand new lol. i also tucked a few wires but doing more when i get the chance. tucked the clutch cable, took out cruise control, and going to put the injector wires under the intake manifold to make it cleaner. Went to pick N pull today and found these accel 8mm spark plug wires on a 92 da they have there. there a little better than stock so ill have to see what they do lol.
with my set up it should pull very good and strong for a 4 door :stuck_out_tongue:
thanks erick. no powersteering and alt belt tho so cant start til tomorrow.
Back to work. Slacker.:whip: I kid. Keep it up mang.
haha very funny. will be running in two hours. gotta put half shaft in, axles, suspension back on, oil and antifreeze, alternator belt and bam done!
Its going together good Joe, can’t wait to take a ride in it :smiley: lol
heres the final proof that its running/driving.
