There are 4 parts that i dont know what thery are, please tell me what they are and were they can be relocated to.Thank you
clearer pic.sort of
1 underhood fuse panel
4 cruise control
2 and 3 i cant make out in the pic
- fusebox- many relocate it to under the PS dash
- the picture is kinda blury, but looks like some relays possibly (not 100% sure)
3)I cant tell what is being circled. the car looks like a 92-93, so there should be no resistor, which first came to my mind. - cruise control (I dont know if you can relocate it though)
someone with a 92-93 or more experience in this area can probably help you more though.
i added a pic to maybe help
in second pic part on drivers side is injector resistor box
can it be relocated and if so where to?
option 1: remove the intake manifold brace and bolt it to the bottom of the intake manifold using the bolt hole for the brace.
option 2: make a dummy plug for it, solder on obd1 or obd2 injector clips, and use obd1/2 injectors.
i hava OBD1, its a B16b
i guess i will remove the brace
is it at all possible to relocate the cruse control?
and what is that thing on frame by the intake (cold air/ram air, not intake manifold) the one with the arrow?
[QUOTE=jdmb16b;1738371]i hava OBD1, its a B16b
and what is that thing on frame by the intake (cold air/ram air, not intake manifold) the one with the arrow?[/QUOTE]
Those are the A/C relays, you gonna have to do a wire tuck i would bleive:whisper:
thats what im getting ready to do, i need to know where they all go
just go with obd2 injectors. u have a $5k swap. lol
ok lol
btw, think i could fit this in there?
http://lib.store.yahoo.net/lib/twincamtech/arcek4lg.jpg
its a beast
any g3 intake requires you to relocate the battery.
arc box should fit, not sure about the power chamber arm but it should. the j’s intakes normally need the brake proportioning valve relocated. but i think there is a password copy that fits with no work at all. the stock g3 box fits no problem, just needs custom mounting. the comptech intake for a dc is also pretty neat but it requires you to cut your frame rail right behind where the front crossmember mounts for the snorkel.
awsome,
any more on what the parts are?
- fusebox
- relays for lights i think.
- Injector resistor box
- cruise control
thanks.
where can it all be relocated to?(i know were the fuse box can be)
were can i relocate the cruse control to?
I removed mine. Don’t really use it all that much. Plus I have an aftermarket steering wheel; & didn’t want to make/buy button mounts.
I suppose you could mount it in the fender well. Make a hole for the cable to fit through & bolt it on w/ the bolt heads facing inside the bay, to minimize the items shown. If you remove it, then you also free up the brackets by the resistor box that hold the cable.
I’d mount the item by the intake on the inside of the fender well too. If it attaches to the headlight wires, then it’ll have to; 'cause they get tucked in the fender wells if you do a full tuck. I did a partial tuck, & just stuffed them down by the mounts.
:getsome: :manual:
Corniest quote ever: "Get yours today! JDM isIN!"
thanks, i also have a after market steering wheel (momo) and mounted the buttons on the ash tray.
thank you, i will deff do that
