looks really good…i the way the wheels butterfly…thats oldskool right there…car dumped to the ground boucing everywhere…haha…pretty clean car…
well i installed them yesterday i’ll post some pics …
I just picked some up from a junkyard for 30$. The guy workin there asked me “how much do these usually go for” so I said about $40 dollars. One had a little crack in it, so he gave them to me for $30. I’ve already started removing the clips and cutting a little off here and there. Now I’ve got to get them painted, once I’m done making them fit. They wouldnt look right on my GS-R with the painted moldinds, if it stayed that gray.
Well I’ve got them cut, painted and mounted. I think they look great! It’s just a tight fit between the door and rockerpanel, so I’m thinking the paint on the skirt is going to last VERY long. But I can manage…
Overall it was pretty easy to get them on, the hardest part was just getting the paint ordered.
Sweet and clean. One question though: Did you cut the top part completely off or does it fit under your door?
It slides in between the door, but it’s a tight fit. If I were to do it again, I’d probably cut off the whole section that’d go under the door. My doors are pretty tight to the rockerpanel. Because the paint is already starting to chip on them
Ahh that sucks dude. Paint chipping is the last thing I was happening to my newly painted car. I guess I will be cutting off the whole piece that goes under the door…Thanks for the info though!
Well the paint is chipping off of the Skirt, NOT the door. If that makes any difference to you.
i can not see the pictures!!!
wow i made it to teg tips forum!
yes, this car is not totalled :sad:
and yes, i do live across from mira loma. if you drive by now, youll see two DAs in the driveway
“and yes, i do live across from mira loma. if you drive by now, youll see two DAs in the driveway.”
I’ll be darned…I thought that was where that pic was taken.
what good is a teg tip without pictures???
I’m doing this right now… too bad i don’t have a table saw. That would’ve made my cuts so much smoother!
no pics.
my ek sideskirts look better
not cleaner, but better… hahahaha
poop on your face
:rockon:
refresh the page.
doesn’t work… i’ll be doing another updated write up on this after i’ve finished mine. Waiting for paint to dry right now!! :rockon:
awesome!
I’m patiently waiting to land on some DC sides and a 94-97 accord rear lip to go w/ my stock lip
damnit! I screwed up on the paint!!! It was all looking nice. It matched up to my paint PERFECTLY, but then i slapped on the clear coat and BAM! Instant darkness! The skirts are darker than my car after i put on the clear coat! What’s even worse is that when i was moving them around, i banged it against the wall and the paint is all messed up now! I’m so pissed off!
