Well, I just got back from the track, and I was realy hoping to beat my 15.268, but no luck
My friend with a turbo G3 teg and only 8lbs of boost was only able to run a best of 14.8
I guess it was pretty damn hot for the end of Sept, it was hotter than when I went in mid August… wierd
I guess I will have to wait for next year for better times…
by best was 15.341
I1: 2.285
I2: 6.694
I3: 9.849
MPH (I3): 70.449
E.T.: 15.341
MPH: 89.513
well, my 60ft times are improved from last time at the track, but my ET is worse
WTF
and my camber is still a little out. With proper camber I’m sure I could do even better
I had two 2.2 0-60’ times the only 2 times I ever drag raced before at the track. Oh i was on Parada spec-2’s. I’ve never been there since.
:rockon:
system
5
whats your setup? not a bad 60’
what tires are you running and how are you launching ?
if you are asking me
I have a b20z, Comptech header, AEM CAI, Thermal Exhaust and Skunk2 IM
I have 16" tires with 205/45/16 Khumo Exta Supra tires, the are relatively new
except my camber is about negative 2 degrees… if it was perfect, I could have great 60’ times
I used to just rev to 2000 and dump the clutch, but for my recent runs, and lower 60’ times, I reved to 3500-4000 and gradually let out the clutch
