I picked up a fully loaded 92 with working everything for 400.00
To start it some times it starts normal, other times I have to pump the clutch pedal in a out a few time and then it starts. Sometimes I have to pump the clutch pedal and the turn the key on and off a few times. then It begrudingly starts. What could the be cause of this? Please let me know ASAP as the car is for sale again.
I am new to the DA but not to honda’s. I am a member of cb7tuner.com
Pump clutch to start, check “Clutch Interlock Switch”
Turn ign, on and off to start, check ign, switch, a bad ign. switch is a common problem on a G2.
Pump clutch and turn ign. switch on and off, check starter relay.
Assuming you mean engine will not turn over when you say it will not start, next time is will not start do a bypass jump, using a scrap piece of wire with one end connected to the batt. pos.(+) terminal, touch the other end to the solenoid terminal on the starter motor, [thinner lead that unplugs] MAKE SURE CAR IS NOT IN GEAR, engine will crank even if ign. switch is off.
If engine cranks, [starts when ign. switch is on] the problem is not the solenoid or the starter motor, make sure the solenoid lead is tight when you plug it back in again.94
hey guys so i figured out that it wasn’t my ignition switch.
In order for my car to turn on I actually have to push in my clutch all the way in. When i say all the way in I mean all the way in, as if i was doing my girl and she says harder, and i push push and push. Its funny how i sometimes compare my girl to my car. Love them but gosh. so complicated at times.
any who. hope this helps to anyone that has to pump their clutch in order to start their tegs. Try pushing the clutch in all the way. I have to do it with some strength. But this doesn’t apply when i’m driving normally and shifting gears, only to start my baby.
[QUOTE=pulga37;1984207]as if i was doing my girl and she says harder, and i push push and push. Its funny how i sometimes compare my girl to my car. Love them but gosh. so complicated at times.[/QUOTE]
