[NJ] CRX SIR B16A S1 Transmission F/S Cheap Will ship
Whats up everybody
Pics added!
I have an S1 short geared cable transmission from the JDM CRX SIR
Non lsd.
This trans was bought with my SIR swap for my CRX Si. I purchased it from Kearny Engine Depot in Kearny NJ
I put maybe 10k miles on it and when it was purchased they said the swap had between 40-60k kilos.
The trans makes no noise, doesn’t grind, doesn’t pop out and never gave me an issue.
The bad
The CRX was in an accident. Nothing incredibly serious except it hopped up on a curb and sat right on the trans casing. because of this there was a very small hole put in the casing. It landed right on the casing bolt bump and damaged the threads and the casing bolt.
When this occurred I had the CRX towed to my house where I pulled the trans that same night and installed my ys1 trans from my Integra.
I have drained and filled the trans fluid twice using Honda fluid prior to this incident. seems like overkill in 10k miles but that’s just how I do things. I am asking a very reasonable $200 for the trans as is because I know the casing will either need to be replaced or welded. If I had the transmission with me here in Colorado I would fix it but I figure since I am going hydo in my DA and the CRX has good ys1 in it and is not going to need a short geared trans ever again I would sell this to someone who will actually use it. I know how rare these are getting so please no low balling.
I guarantee that the internals are perfectly fine and in working condition and that this trans was never run without fluid while in my possession.
So if you are interested in purchasing the trans it is available for pick up in Montville NJ at my parents house or it can be shipped anywhere in the world at buyers expense
PM me email me or text me
happletom@gmail.com
2016873396
to the top
Hey I sent you a text, please let me know ASAP very interested as the b16 tranny I bought ended up grinding a lot.
Re-text me I put the wrong number. I should have proof read the post lol
It has been corrected
Great price!
lsd?
Can you post some pics of the damage?
I would be very interested.
Thanks
Non LSD
edited original post
I thought I mentioned that
[QUOTE=idriveahonda;2310035]Can you post some pics of the damage?
I would be very interested.[/QUOTE]
I will get pictures as soon as possible
I am currently in Colorado Springs and I have my family taking care of all of my sales back home.
So as soon as I get the pictures from my brother I will post them.
come on no one wants this!!!
pictures are up.
The casing is very dirty as you can see. I will have it power-washed before it is shipped
as you can see the damage to the casing is not that bad and if I was home I would repair it.
If it doesn’t sell by the time I get home then I will be keeping it.
so if you want to make your non vtec integra quicker without swapping the motor here is your chance.
or if you need shorter gearing on your b16 or gsr swap and that ls trans you have just isn’t cutting it here you go.
you could have the casing welded then drilled and tapped or swap the gears into your 90-91 ls casing.
so is the case actually broken? It looks like it was just “grounded down” on that nub where the bolt goes through? I see a hairline crack I believe but can’t really tell. Just wondering if it’ll leak as is or if I should split the case. I’m pretty interested so if you can give me your best price shipped to 93060 we can go from there. Thanks.
