i have crome pro and when i load my datalogs to watch later i get all the information as normal. im sending my dls to my friend to look at who also has crome pro and when he loads the dl the afr for his is 0 for the entire thing but all the other information is correct its just the afr that doesnt show up. if anyone could help me out by loading one on my datalogs on their crome pro to see if they get the same problem.
does anyone have an idea on how to fix this?
http://www.mediafire.com/?4gwiq3wakq63nr6
Don’t you need to be using a wideband O2 to get proper A/F readings?
If you do have one and are still getting a 0 reading then I’m at a loss lol.
yea, im using a wideband. my datalogs show all the information fine. its just when he loads them on his computer he cant see the afr.
Figured that you were, was just a shot in the dark… that is puzzling though.
solved…
he had to set the offset on the tuner logging tab and it just worked
