no brake lights..
my brake lights haven’t been working for awhile now, and it’s bad…
i’ve checked my fuse under the hood, and the switch on the brake pedal, but i get no response with i hit the button…
what else can i check/do ?
when you say you checked the switch on the pedal, did you checked it with a multimeter or simply did a ‘visual check’?
If the switch is good, probably a bad wire or a bad ground somewhere.
HTH!
i just did a visual check…
would you know what wires in specific could be the root of the problem? i have a helms, but i find it a bit overwhelming at times
hum, sorry, don’t know the specific colors… But simply test the switch with a multimeter to see if it conducts… Could be as simple as that!
