I redid my brake system, replaced everything. I went to bleed the system and have no pressure in my brake pedal what so ever after bleeding it many times.
It is a new master cylinder, and i have read a few threads where the master cylinder was the problem, do i need to get another new master cylinder?
or is there another common problem i over looked?
You need to follow the Haynes or helms serive manual for brake bleeding procedure.
If you don’t have one then buy mine in the for sale threads.
did you bench bleed the master cylinder/
