ok i just change the gas tank because the previous tank was rusted!
now when i go to start, it doesn’t start check for fuel no fuel coming out the line.
the fuel pump is working because i could hear it from the back.
what could be the cause?
what should i do?
If u hear the fuel pump running then u probably left the rubber fuel line off of the pump inside the tank…or it has a hole in it. How is it that u checked for fuel? Did u crack the bleeder screw on top of the fuel filter and crank the engine. Remember to be careful when working with the fuel system…nobody wants thier car on fire.
well i removed the fuel filter then turn on and off the key to activate the pump but no gas coming out the line. tried cranking it but same thing o gas.
Did u ever found out the problem cause mine is doing the same thing
