No Heat
I Just Did A B16 Swap And Theres No Heat In The Car Only Air Coming Out.what Do I Checc??
did you connect your heater hoses or did you loop them up somewhere?
What he said + did you replace the thermostat and water pump before you put it in? If your thermostat is stuck closed you might not be getting flow through the heater core. You should have replaced the water pump too, but if that is going bad you will have bigger problems then just a lack of heat. :uhoh:
